100 more HP
AK-RWC
south central
AK
So I finally got my Scrambler in to a local shop called Underground Performance. The owner is a wheeler, but really made his mark doing custom performance tuning with his dyno. I realized a couple years ago it would be infinitely more efficient to get my own fuel and timing maps dialed in if I could strap it to a dyno and get a constant load.
My first trip in was a bust because the ECU wasn't sending the advance signal to the ignition. I took care of that, and then had to wait for another spot to open up. I finally got the call this week.
Nick found me another 100 HP hiding somewhere inside my 401. I'm going to see a few dyno pulls and pick up the Jeep in a couple hours.
I went from being a little scared of my Jeep to now I expect to be completely terrified. I can't wait! I'll post the rear-wheel horsepower dyno sheet on my build thread when I have it in hand.
Sweet!!!!!!!!!
I wonder how my stick 401 would compare.
What all do you have done to your 401?
What? No Hellcat?
Apparently one of the EJS Concepts that will be in Moab later this month:
Yes, we need the details....401 specs and what its making!
Details
Need dyno results [emoji2]
Sent from my SM-N910P
The thumb drive he was going to give me with all the data was having formatting problems. I just needed to get back to work at that point, so I told him I'd get it later or he could email it to me. I haven't received an email, and he was closed over the weekend. I'll try to get back down to his shop later this week.
- Indy 401-SR heads
- Edelbrock Performer intake
- Venolia forged pistons
- bored .020
- 8.5:1 compression (as measured)
- shot-peened and stress-reduced OEM forged rods
- OEM forged crank
- Comp Cams XE262H cam: 1800-5800 range, 110 LSA, 262/270 advertised, 218/224 at .050", .493" intake and .500" exhaust
- Thorley tri-Y headers
- dual Flowmaster 50s
- 700 cfm Holley ProJection 4Di
- internal valley oil-line to rear main
- modified oil pan to hold an extra quart
- Performance Distributors DUI ignition using a 7-pin HEI ignition module to control advance through the ECU
It's not going to win any races, but I wanted dependability and the ability to run pump-gas as much as anything else. I'll take it. I'm a big fan of that incredibly flat torque curve.
Added links to a couple dyno videos on my build thread if anybody wants to hear the engine spool up.
