1963 Cj6
onesourcemike
Wilmington
Hey Guys,
Sorry for the long post!!!!
I have been a Scrambler guy for years and will never sell my 1981. I came across a CJ6. I have always wanted one and like the way they looked. I have only seen a few in person so I thought it would be cool to own one.
Make a long story short I located one in San Deigo CA! Its a 1963 that has been completely re-done. Its alot more then I want to spend but wanted to hear what you guys think of it. Do you think it will hold its value like our Scramblers will. :jeep:
I guess I'm hoping you guys will talk me out of these, I also found another scrambler for half the cost but it need work. I need help picking one.
Here is some info on it. I will post a picture tomorrow.
Rare 1963 CJ-6 extended body
Off Frame Rebuild
Only 6,200 miles since complete custom rebuild.(7 years ago) Body and frame sand blasted and painted. Bed and bottom of body spray lined. New Motor, Trans, Front & Rear End, Seats, gauges, wiring, suspension, etc. All work professionally done.
Axles and Suspension Work Done by MIT in El Cajon
Motor – Engine Professionally Ported, Polished & Built, by Pete Thompson’s Racing.
Dyno - 435 Lbs.Trq, 380 H.P. - Broad Power Band
383 Chevy 4 Bolt
Holly Double Pumper Carburetor,
Edlelbrock Torker Manifold
Crower Cam, Wisco pistons, Dart II Sportsman Heads
MSD Ignition
Braided Steel Lines
Hi-Torque Starter
Optima Battery
Headers
Flowmaster Exhaust 2.5” with side cut outs
Pre California Smog Test
Tran- New Venture 4500 - 5 speed (with Granny gear & Overdrive)
Dana 30 Transfer Case
Front – New Dana 44 Axle
Detroit Locker
2” inch wider track
4:56 Gears
Disc Brakes
Spring Over Axle
RS 5000 Shocks
Rear - New Dana 60 Axle
Detroit Locker
2” inch wider track
4:56 Gears
Spring Over Axle
RS 5000 Shocks
Tires – Mickey Thompson Aluminum Wheels
33*12 Inch T/A Mud BF Goodrich
Body -
Bed & Bottom sand blasted and Spray Lined
Custom trailer hitch
Mount for carrying motorcycle/bike
Two Mounted G.I. 5 Gallon Gas/Water Cans
Custom Full Soft Top with removable side panels
Bikini Top
Interior – Interior Spray lined
New Custom Leather Seats
5 pt. harnesses
All new VDO gauges
AM/FM
CB Radio
Alarm
Frame - Partially boxed frame.
Full Family Roll Cage (6 points) mounted to frame
Custom Skid Plates
Misc. - Tilt Steering Column
Power Steering.
Power Brakes.
Completely Re-wired.
2 Gas Tanks – 15 Gallon & Larger Custom
Warn XD8000i Winch with accessories
4 ft. jack
That depends on the price. CJ-6s don't hold value like Scramblers do, at least up until now. Any collector-driven value has been lost due to the custom build. If it's something you like, and it is less expensive than what you're planning on spending on a similar custom build, I'd say go for it. However, don't plan on it being an "investment".
Just my $.02, of course.
Craig
Thanks for the advise! I'm thinking I can get it for 11K. I would think the parts alone add up to that. He told me he has 40K invested in it. I'm sure almost half is on labor since a shop did it!! Who knows, thanks again for the input!!
Would you spend at least $11K on building a comparable rig? It sounds pricey to me, but if it'll save you money/time, then it's definitely a consideration. It honestly doesn't matter how much the previous owner spent on it, as it'll never be worth even 1/2 of that.
Craig
I agree, If I could get what I have in my 81 Scrambler I would sell it today. I'm up in the air, it sure looks good. I just think thats alot of money. If I know I wouldn't get hammered when re-selling it I would do it.
