- Houston
- TX
I will add, nice build. I like your method of right parts the first time. A cowl replacement is rare and that takes talent.
I typically try to match the motor mount material with the transmission/transfer case material. Rubber/Rubber, Poly/Poly etc.. The reason is for rock crawling or high load situations, I want the drive train to move as one. If you had 40+ tires it would be different. If its mainly street / light off road it will be more than adequate. The drive line vibration is minimal with these power plants. I would focus on the big stuff. I think you have found that the 5.3L swap may not be as common as you think, and there are ten different ways to skin the cat. If you put those of us on this board alone with 5.3s I think you would see vastly different approaches to the same problem. Its like Gumbo. It cant be wrong, its still Gumbo.
