The following are some tips for getting your Scrambler ready for the trails of Colorado.
Preparing your Scrambler for the trails of the Colorado mountains requires focusing on high-altitude carburetor tuning, cooling system efficiency and reliable braking.
Mechanical & Trail Prep
- Engine & Carburetor: Properly tune the carburetor for high elevation (7,000–13,000 ft) to prevent running too rich. Ensure a reliable ignition system.
- Cooling System: Ensure that your cooling system is in perfect condition with new hoses, sound radiator, proper thermostat and new radiator fluid. Steep inclines and thin air will cause over-heating on weak systems.
- Brakes & Steering: Properly functioning brakes are essential for the steep descents typical of the mountain trails. Check condition of pads and rotors, shoes and drums, hard and soft brake lines, master cylinder and the brake fluid itself. Replace, or upgrade, any questionable components before you hit the trails. A properly working emergency brake is a must have. Regarding steering, ensure that all steering linkage is in good condition and greased.
- Tires: While aggressive tires are not typically required for the trails we will be on, they do need to have good tread depth and relatively new. All-terrain tread patterns work well. Also include a good tire gauge that will read single digit pressures. Ideally, this gauge will allow for airing up and down. There will be sections of pavement on trail days so an air source for airing up at the end of the trails would be a good addition. CO2 tanks or portable compressors work well.
- Fluids: Check the following fluids: differentials, transmission, transfer case, power steering, master cylinder and coolant. Now would be a good time to fully service all fluids.
Essential Gear
- Recovery: It’s important that you have solid tow points both front and rear. A tow strap, or rope, with a #30k load rating and shackles (hard or soft) should be added to your kit. Tree saver strap. A winch is not required but does make a nice addition.
- Tools/Parts: Bring spare u-joints, axle shafts, belts, hoses, and fluids. A tool kit with wrenches, rachets, sockets, pliers, etc.
- Safety: Pack cold-weather gear (even in summer), sunscreen, and altitude sickness remedies. It is also recommended that you have a full first aid kit in the Jeep and any medications that you are currently taking.
- Communications: We will be using GMRS radios on the trails.
- Food & WATER: Bring plenty of water for all passengers. We will typically be eating on the trails so bring for lunch for you and your passengers. No alcohol on the trails.
- Full Top: The weather can change quickly in the mountains. Rain and even snow can roll in quickly. The ability to quickly add side windows to full soft tops, upper windows to half doors, etc, will keep your passengers warm and dry.
- Misc Gear: Leather work gloves. Flash lights. Charged fire extinguisher. Duct Tape. Rachet straps. Shovel. Nuts, bolts, screw assortment. Fuses and wire. Rain gear for all passengers. Maps or mapping app for phones/tablets.
This list is not all-inclusive but should be a great starting point to get your Scrambler ready for the Ouray National!
