258 tuning questions..
K9rockydog
Glendale
Az
ok.. I put the pacesetter ceramic on, and a flowmaster can.. it sounds great except under load.. wondering what needs to change..
what I have is..
- a 2 bbl carb (not sure what)
- not sure what distributer it is, but we did go through and adjust the timing
-stock intake
-no coil
-no clue how to improve it.. :banghead: except mebbe a different distributor w/coil etc..
or mebbe re-jet/adjust the carb..??
Got any other info?
Is it rattling/pinging under load? We talking the motor sounds bad or the exhaust sounds bad?
yes to the rattle/ping under load, and the exhaust sounds great when just waddling around..
also.. when its in 1st, under 1100 rpms, it does it.. (taking off from a stop) but then when it gets to the sweet spot around 1900-2500 it sounds awesome.!! most of that being harmonics etc.. also.. pops like crazy when ya dump the throttle..
carb (not sure yet what it is, gonna figure that out tomorrow) is reasonably new..
my thought is it isnt anything too bad.. just mebbe a carb rejet.. or mixture adjusted..
Sounds like too much timing or the vacuum advance is hooked up wrong. Carb may need adjusted as well. Oh and you have a hei distributor. It has a built in coil. Can't get much better. Your carb is a carter. Lots could be wrong with the carter . They plug up easy
sweet.!!! thanks for the info.!!!! so should I go find a motorcraft..?? or fiddle with the carter..??
If it were mine I would focus on timing
A) pull a plug and see if the carb is lean/rich or just right (Just for knowledge b/c if it is wayyyy lean then it could... be the carb)
but
B) My guess is your ignition is advancing very quickly once you open the throttle. So while it should be at 10-12* at 1500rpm (Note: Look up 258 numbers, I am ball parking) yours is jumping high/maxing out immediately. Now timing should be around 32* BTDC at 3000rpm (remember my note on 258 numbers :) ). This is why yours is bad off idle but comes back around as rpm increases. Also why it is popping b/c it is advancing so much that valves are open when it is lighting the fuel.
Your solution according to my internet guess is-- Check your ignition advance, back your timing down, make sure your advance is hooked up to ported or non ported on the carb???, or even replace your dist for one that is curved for a 258.
Best of luck, it is like a puzzle and by the end you may be a 258 ignition expert, kind of like I became with a SBF in an old bronco.
YJ-8
but
YJ-8
well... just talked to my mechanic neighbor that timed it last time, and he said..
"why didnt you TELL me..!!??? we just took too much off last time, ya jackwagon..!! I'll be home tomorrow, and we can put a little back on, it should clear it right up..!!"
so.. for now.. looks like problem solved..
ok.. so.. going with all that's been said.. (and given I have a limited budget, so need to spend wisely..). would I benefit significantly from putting an offenhauser intake on in place of my stocker..?? (250.00 or whatever he has it listed for is doable, but a big chunk that wont be quickly replaced)
or just spend that towards other stuff..??
(edit). nevermind.. just noticed is for a 4bbl..
I made the best horsepower at 28 degrees total mechanical advance using a HEI and running 12.8-13 A/F on my old Jeep with the 258 and stock carb with a dual outlet manifold. I had the total mechanical in by 2600.
