scramblerbob
I got my 2000 4.0 in my 81 scrambler and after a few minor problems I got it running. It runs great but the only way it will start is if I pour fuel down intake. Must be some sort of senser thats keeping fuel off untill it fires. any sugestions as to where to look? Secound problem is where to hook temp gauge? I keep reading about using the sending unit in rear of motor and not the front because the front is used by the PCM but as far as I can see there is no rear sensor on the 2000. and what about the oil pressure gauge does it need to give imfo to the PCM or can I just disconect old wires and sending unit and replace with the old 258 wire and gauge. Thanks for any help you can give me and I be glad to answer any questions that I can from what I've learned so far. One thing I did differntly then most was to keep the existing fuel rail with no return line and fuel pump in tank. I have a special 35 gallon tank that came with my scambler so I had a machinest cut a hole in the tank and a ring to hold it in place. I then cut a 6 inch sqaure hole in my bed and made a cover with the cutout that screws back on. I figure I got the best of both worlds, fuel pump should last longer, no return line, and I don't even have to crawl under my jeep if I ever have to replace it. Thanks again Bob
