4.0 Upgrade Checklist
eyesautomatica
Bloomsburg
PA
'84 Scrambler with 258.
Mopar fuel injection installed.
So, I'm ready to convert to the stroker motor with a 4.0 head, and I want to make sure I have all bases covered.
I'm going to get a remanufactured head online, and new seals.
PO recommended a header to replace the cast iron manifold, thoughts on that?
PO also says the existing valve cover should fit the new head, is this true? Definitely replacing the seal as it seems to be leaking.
Anything else I'm missing? Words of wisdom?
See this link:
http://offroad-review.com/new/index.php?page=68
Here's their list:
PARTS LIST:
- 4.0L Head Provided by Koller Dodge
- 4.0L Head Gasket
- 4.0L Exhaust Manifold or Header
- Exhaust Manifold Gasket
- 4.0L Valve Cover
- 4.0L Valve Cover Gasket
- Tubes of QuikSteel Epoxy Putty
- Sand Paper (fine)
I just pulled the header and put a cast iron back on..... Three years of warping, tightening, and finally cracking weren't worth 6hp.
IMO-- go with a quality header and you will be fine. I have 40K miles on my Borla and no problems, never even tighten it up again after a few hundred miles. You want one with a thick flange to prevent warping. Others also say Banks makes a good one. I had Bassaini ceramics on a small block ford once and they were very nice. Only complaint I ever hear about the headers is cracking if you go through deep water when they are hot, but I have no first hand knowledge.
My 258 valve cover fit on my 4.0 head.
Yj-8
Is your cover plastic? If so general consensus is to switch to an aluminum one.
I think I heard banks headers had a lifetime warranty but they "cancelled" that after so many returns. Make sure you get the right exhaust manifold, the later 4.0 heads have different exhaust ports.
My valve cover is Aluminum, it is the factory cover on my 1990 258. If yours is plastic I would switch to metal.
If you want to save $$$ you Cherokee 4.0's had a "factory header" or some may call it a "tubular manifold" which I guess would perform much better than a cast iron manifold. If you get one look it over closely for cracks (yes, you can weld em) but why not get a good one to begin with.
YJ-8
