Hard to call it a Scrambler when it started life as a CJ6, but I do have to say, it is growing on me.
Not a fan of the lines of the roll cage into the rear, but like the fact that it is there... he almost smashes his head on it getting into it and I am a taller then he is, so I would want that to be a bit different lay out.
I also 50/50 on the U and the S shape together of the openings, I am thinking that 2 S shaped ones would flow better, but have CJ5's, they are no fun to get in and out of with that there with steering wheels, etc.
As for 2 U shapeed openings, it would be much longer and probably wouldn't look right either.
I agree with Jersey, the blacked out diamond plate seems to be lost on the back... probably would need to either go actual color, or use a CJ7 rear and just end it after the wheels.
Tops and Doors would be my concern up here in the east, warmer climates wouldn't have to worry too much... but you would need custom soft tops, doors, etc. if you went that route.
Overall pretty cool, but I woudl imagine it cost quite a bit to get it built and selling for $12K, it probably hit the wallet pretty hard.
