I guess I got called out. I like to talk/write, so here goes:
You can easily run 33"s to 35"s with a spring-under lift; anything from 2.5" to 4" will work. You'll have less modifications to worry about staying under. For that matter, with some serious fender trimming, I was running 35"s (no swaybar, full articulation, limited rubbing) on my CJ-7 with stock springs. If you shop around you'll find really complete, high quality SUA kits.
Will you need ram-assist with 35"s? It depends on the kind of wheeling you want to do. If you're going to be in the rocks 100% or doing competitions, sure, 1-ton axles and ram-assist will be good with 35"s. Otherwise, it's probably overkill. If you're keeping a Dana 30 front, don't even waste your money on ram assist.
Any "kit" for SOA is still going to require a fair amount of work, and you may or may not be able to assemble the exact parts you want on your own. What are you going to "need" depends on what you plan on doing with the CJ and what you're willing to tolerate. (I've seen a 2-piece AMC 20 with 2.73 gears running 44" Boggers. I'm not kidding; I saw this guy in Panama City Beach at a gas station and asked him "***?" I was laughing so hard I thought the hubs were going to get scared and spin just listening to me. I don't think he could have driven over a curb with that CJ-7. But it was big, and he only drove on the street. Good for him. I wouldn't tolerate that, but if my junk is going to break I expect it to happen on a trail instead of Walmart.)
I went SOA for one thing only: in Alaska, we have lots of water crossings, and I needed to get higher. I built my CJ-7 when I was on the east coast, and it worked great for Paragon as well as parking garages. But there are not really any river crossings. As soon as I got back with my home club, my limitations were immediately apparent. Without a lift or a snorkel, I could tool along just fine until we got to a fairly simple water crossing that left me on the near bank.
Front YJ springs are wider and longer, providing a better ride irrespective of the lift amount. You will need to move your shackle hanger forward. There are lots of instructions on the Internet about adapting YJ springs to a CJ. Keep in mind that 8s typically had one of the heavier-duty rear spring packs. Since there was never a YJ-unlimited or YJ-8, you'll need an extra leaf or two in the back. Or you can just re-use your CJ springs.
Your actual lift will be based on the thickness of your axle, added to the spring perch, added to the spring pack, added to the advertised lift (if any) on the spring. Going SOA with stock CJ or YJ springs will easily net you 5." Keep in mind you'll need to address pinion angles, and on the front axle, you will need to consider how the pinion angle changes impact the caster angle. This is also your suspension mount: nearly the entire weight of your vehicle will be sitting on these four welds. Make sure you get a good weld, or find someone who is competent. Keep in mind that CJs came from the factory with different spring packs. That fact itself makes making a kit and guaranteeing a particular ride height nearly impossible.
You will need longer driveshafts, possibly with CV joints. Some people get away without CV joints, but I can't predict it for you. My other CJ-7 only has a 2.5" lift and I HAD to get a CV shaft (much to my dismay). You will need longer brake lines. You will need a longer emergency brake line. You will need longer shocks. You will need longer bumpstops. How much longer? It depends on your axle, perch, and spring thickness, plus whatever your lift is. If you switch to YJ springs, expect a little more droop in the front too. Oh, and everybody I know who has gone SOA in a CJ-5/7/8 has needed to trim the skidplate so the front driveshaft can clear.
You might be able to address some of the driveshaft and skidplate issues with a drop skidplate, but I've always wondered why would I want to lift most of my Jeep just to drop the skidplate? Dropping the skidplate also changes the angle of the engine, putting more stress on the engine mounts and creating possible clearance issues with your engine fan and the shroud (if equipped). Dropping the skidplate also changes the transfercase yoke angles, which may actually exacerbate driveshaft vibration for one or both of them. If you have a mechanical clutch, skidplate drops will change your linkage geometry. You also may need to modify your transmission tunnel cover since the relationship to your shifters will change.
Now lets address axle-wrap: you'll have it. You can buy perches that are intentionally oversized to help control axle wrap, and corresponding spring plates, but in doing so you limit articulation, and it won't cure axle wrap entirely. At some point you'll probably need to consider ladder bars or an anti-wrap/traction bar. (I'm also considering kicker-shocks.) Your horsepower and right foot will impact how badly you wrap. I am going to bring extra u-joints and try to go easy on the skinny-pedal until I have axle-wrap addressed. One benefit to my Tera-60 is that the top is already tapped so I can add a plate to begin welding up a bar of some kind.
SOA puts more stress on the spring pack, causing them to sag prematurely. Rubicon Express even made an SOA-specific reverse-military wrap spring pack for the YJ that a buddy of mine ran, and he STILL got used to replacing springs every two years due to sag. The OME springs that I picked out are particularly known for sagging quickly, but they are also known for flexing well and providing excellent ride. With how high I think my 8 will end up, I'm OK with a little sag.
Last but not least: steering. Going up that high will give you bump-steer, which isn't exciting. A 4" drop pitman arm and/or maybe some kind of Z-link will work, but it's going to suck. If you want to do it right, you'll need to find a way to get that drag link sitting above the spring pack. Which means you're probably looking at high-steer. I'm getting away with a slightly ghetto steering set-up since my Scout knuckles have a relatively high arm to begin with, and they are machined to accept a TRE from the top. This is safe and gives me a fairly good angle, but I may still pick up a dropped pitman arm, and ultimately I have flat-top knuckles to eventually go high-steer.
So back to the initial premise: what are you doing with it and what can you tolerate? I've seen SOAs that were street-queens running stock driveshafts (maxed out), factory re-routed brake lines to allow a little more droop, a booty-fab Z drag-link, and nothing else more than new shocks. Does that work? Well, sure, sort-of. You might even get away with it offroad. But I wouldn't consider that complete and I wouldn't run it that way long-term.
IMHO, the Rocky Road kit looks like a compromise SOA system: it gets you SOA and you can drive it, but not everything is addressed to my satisfaction. Obviously they design it to bolt on a stock Jeep, so if you've already done some mods, you may or may not use all their parts.
Here's how I did it: I knew the springs I wanted, measured my axle tube diameters, and went from there. I picked 2.5" lift YJ OME springs, with an add-a-leaf in the rear to accommodate the added weight of the CJ-8. OME doesn't actually make springs for any CJ, let alone for the 8. When I ordered my TDK frame, I had Jeremy build in the spring outboards for my Scout Dana 44 front, along with adjusting their length for YJ springs. I ordered new YJ shackles and cobbled together the bushings from several sources. Since I already had my axle modified for 8 degrees of caster, I decided to chance keeping an identical pinion angle, and had a buddy who knows how to weld cast burn in my spring perches (after I did a lot of grinding on the housing). I bought new u-bolts from Six States Distributors. I ordered anti-wrap perches and front spring plates online. The rear-plates for my Tera-60 are skid-style from Currie: I'm hoping that the added length of the plates combined with the perches will limit wrap (recognizing that it also limits articulation; this is a temporary compromise to get me on the road). A Scout forum turned me on to a NAPA part number for front brake line extensions, but I still had to go order a fitting to make them work with my Classic Tube hard lines (mounted in the stock location). I had a local place make me a new rear brake line. I ordered a new Lokar e-brake cable to allow me a custom length. I haven't yet ordered shocks. Once the rest of the Jeep is together (to get ride-height), I'll adjust the pinion angle and have a friend who welds professionally burn in the perches, then I'll tow it to Young's Gear to get driveshafts made.
