73 J10 Heater Core Replacement -
Remington19
Stevensville
Didn't know what forum to post this in. I found a descent 73 J10 with a 360 but it needs a heater core and not sure if I can change it or what it might cost to have someone do it. This cost would impact the price that I might offer. Thanks for any info.
Not sure what forum this goes in either but I'm sure the MODs will sort it out.
As for the heater core...Does the J truck have AC? If it doesn't then its not to big a deal to change it out. Plus a new replacement isn't expensive at all. And as a temp fix you can always bypass the heater core by simply routing the heater lines together before they enter the box. It means no heat but will not effect anything until your ready to do the fix.
Also, if you do end up getting it you should make yourself known over on the IFSJA (International Full Size Jeep of America) site. Lots of good folks there as well. :)
And...PICS!!!!!!!!
