a sad story and a opportunity for a engine swap,
Jeremy
Scrambler Fanatic
Carlisle
As you all should remeber my 1981 blue scrambler, not to be confused with the other 5 jeeps in the yard has been sans engine for a while. more on this latter. First the sad story.
My brother bought from my grandfather a 1991 jeep cherokee with 66000 miles on it. He had it for less than 10 days before the engine blew. Mechanics told him that some time in the jeeps history the oil was allowed to run out. reguardless. 7 months latter he got a new motor and got the jeep back on dec 19. Dec 25th My brother lent the jeep to a army buddy so he could go home for the holidays. Which the army buddy promptly totaled in a collision on the PA turnpike. No one was injured due to the collision. I am not sure about the driver when my brother gets his hands on him. Depending on the condition on the vehicle. Which I have not seen yet. I may be able to salvage the drive train out of it to fit up into my 1981 scrambler thus giving my brother something to drive. The wreck was bought back for $158.00 It is a 1991 cherokee. with automatic. My 1981 is a 258 with a T176. What am I going to need to do to make this swap happen? Basically what is involved in swapping in a HO 4.0 inplace of my 258?
www.cjoffroad.com
Probably the best place to start searching. There is a good bit of info here on this board too.
But it basically comes down too, this is probabyl the easiest of all swaps to do. Engine to mount bolts are just a bit different. There is one metirc that is different. Rear engine to bell housing is the same. transmission to Dana 300 might require a spacer, or better yet just use a clocking ring.
be sure to get all wiring and computers. The Auto should be a 4 speed and will have its own ECU. Rember to get it. If you can get a factory wiring manual to help you figure out what to keep and where to splice.
Other than that do a little surfing and there are several good write ups on this swap.
Carl
