AC Compressor Help
RubberDuck
Baltimore
MD
Hey all
I think the A/C Compressor on my Scrambler is on its way out. Previous Owner installed an aftermarket kit with what *looks* like a York compressor but I'm not 100% sure. There are no markings on it that I can find. PO swapped the engine. Engine is a 401, so I'm assuming it's probably a York 209 or 210 with a factory bracket out of a waggy or something like that. It's making a lot of noise and bogging the engine down... tried some oil, no help. It's not the bearing on the clutch either, it's definitely internal. Sooooo, are most of the AC compressors off of FSJs pretty standard? There are tons of them in local you-pull-its to be had quite cheap. Any other donor vehicles to look at that would fit?
Got a picture of it?
If it is a York, you want to replace it with a 210, just for the extra displacement when moving freon thru the condenser.
You should not have a problem getting a good used 210, just grab one off of a waggy or something. the mounting holes and the input/output are the same, its just the hoses that are unique.
One of the things you need to be sure of, and I am NOT totaly clear on this: R12 uses mineral oil for lubrication in the system, and a compatable oil in the compressor. R134a uses PAG oil if I remember correctly, and is not compatable with the mineral oil or the oil in the compresser. You can gum up everything if you mix the oils up...something to think about if you added freon recently.....
You really need to see why your having the problems that you are befor you go and spend $$$
Just my two cents, hope it helps
Peace:cheers:
Thanks. Yeah I didn't add freon but did add mineral oil. It's making a metal on metal type sound.
