Air Cleaner Recommendations
scrambled eggs
chapin
sc
whats the benefit of using my stock air cleaner vs a new set up on my MC2150 carb? i realize i ll need to modify my stock w/ kit but is there any benefit w/ keeping it other than appearance?
There is some benefit - the stock air cleaner (when working properly) draws warm air that it sources from the exhaust into the air circuit to help keep the fuel from condensing when the engine/manifold is cold. (Note - it doesn't draw exhaust, just warm air around the exhaust pipes - you can see the hose running from the exhaust manifold to the air intake if you look around) It's a similar purpose to the heated intake and manifold heater under the carb. When the engine/manifold is warm enough, that hot air draw shuts off and it pulls cold air only from the exterior.
I don't know how much of a difference it would make in SC, but here in Colorado, my intake heater is invaluable when the temps dip below 20* or so, and I'm sure it would also be helpful to have warm air drawn from around the exhaust on cold mornings, too.
I had a 9" K&N filter on mine - you'll need to find the right adapter plate and cover...After I accidentally ran over the K&N filter, I just went with a 9" off-the-shelf filter paired with the original K&N adapter plate and cover.
Something like this: 4wheelparts K&N filter Just make sure you measure the opening on the top of your carb to find the right adapter plate for the base of the filter.
I believe, it's been a while but I believe, something like this will also work: Chevy TBI air intake
I am using a 9 or 10 inch k&n right now. It came with my engine swap on the new carb/intake that came on the rebuilt engine. I agree with the above post about warm air on cold mornings. I don't have that and it would be nice. But my stock air cleaner set up no longer functioned anyway.
