Almost There
JimB
Anna
Tx
As some of you know I bought my Scrambler recently and am trying to finish putting it together as it came in pieces. All I have left
is to install the review mirror and the side mirrors and it will be ready for inspection. The side mirrors will take a bit of time since they
changed the windshied and it doesn't have the existing threaded holes. I am going to have to drill and tap those.
I do have a couple of questions;
1. I have no backup lights. Where is the back up switch?
2. With the hard top on how do the seat belts mount?
I also need to take some pictures and get them posted to try to identify some of the parts. That will be forthcoming.
Thanks fellow Jeepers
Jim
The top would have holes for the top mount for the seatbelt (three point) to go through to get to the roll bar where they mount. Basically, the bolt goes through the hole in the top. Glad to hear you are close to getting the inspection. Good Luck!
Reverse switch is usually on the Top or side of the Transmission.
A NC/NO type of switch.
Carl
Anyone know where to get the rubber pieces that go thru the hardtop for the seat belts?
Find a sporting goods store and pick up 2 hockey pucks. Put them in a vice a drill a couple holes.
