Have an unusual situation that I hope maybe some one else has already been through. Will try to keep is short and simple. 83 with 4.2 and manual tranny. Was trying to diagnose an ignition problem (no spark at coil, except when getting on the key or getting off of it) for a while, then once I got into is, figured I'd replace most of the components due to age. Still no luck, so had it towed to my local shop. Mechanic called on Friday and determined the ignition control module was defective (I had come to a similar conclusion following the service manual checks and had just replaced it.) He had an aftermarket ignition module sitting on the shelf and wired it in and it started right up. Though he said he was getting 16+ volts at multiple locations. Vehicle would not shut off with key, until he disconnected wire at alternator. Put another alternator on it today, and same problem. Unless it happens to be two alternators with bad regulators, any other suggestions for what it could be? I'm going by shop tomorrow afternoon, so hopefully be able to get more details then.
Appreciate any suggestions. Thanks.
