With Sandblast 2026 a few days away...i decided to blow-apart my distributor and build an auxiliary ignition system using an HEI module.
Backstory: My Scrambler has an AMC 360 for a mid-1980's Grand Wagoneer. It is a Marshall rebuilt engine from Napa that i bought in the early 2000's and has always run good. The distributor was a rebuilt unit and has always worked OK...except when trying to climb Test Hill at Silver Lake. As i get to the top of the dune at 4000rpm and max load, it spark-knocks from the ignition timing being too advanced and loses power. It has also always felt a little lazy on acceleration, but not bad.
I have a 1969 Dodge Charger with a 440 than i am restoring and found some youtube videos on how to recurve the mechanical advance and why to do it. The ignition systems on those cars were marginal, and found a company that makes a bracket to attach a GM HEI module to the base of the distributor. I did the mechanical advance mods and installed the HEI module and it runs great, so i thought i would do the same to my Scrambler.
This guy has a few really good videos on re-curving mopar distributors and does a great job of explaining how and why:
I also like this guy and watch a lot of his videos. This one has some additional infomation:
this one explains why to use ported vacuum for the vacuum advance:
Here are some videos showing how to take apart the distributor...its pretty easy once you see how to do it. I did buy the battery terminal puller from Amazon for $10 and it is worth it!
https://www.youtube.com/watch?v=VKIzTSsj5yA
in case you are wondering, you do have to remove the distributor from the engine....i'll explain that later.
more to come...
more to come...
