Anyone ever use those cowl induction things?
gr8dain
Old and Slow
Ashburn
Do those things increase the fresh air in the cabin? I have been noticing that despite the temp of the air outside, the air coming into the cabin is pretty warm. I know the vent/heat knob is working to divert air since when I pull it, I get A LOT of hot air. But I always seem to get warm air coming in. Is this normal? Would that cowl vent thing work to rush more outside air in? Or do you think I have a bigger issue? It only really bothers me when it is warm and I have to have the top up (rain). But summer is not even here yet. I would like to resolve this sooner rather than later.
And if this is in the wrong place, feel free to move it. I just was not sure what forum to put it in. Thanks a lot.
I don't know anything about adding the cowl scoop, but I do know if your fresh air system is working properly, you won't need one.....you'll get plenty of cool/cold air. There are a couple of things to check out on your existing, (all original?) system.
1) When you pull the heat/fresh air cable - make sure it is coming completly out. In the heat mode, the knob comes out from the dash about 2-1/4". In the fresh air mode, the knob will come out 4" or more, so much that you'll think your going to pull the cable out of the cable jacket.
2) Remove the cowl intake grille on the exterior of the Jeep. If you look through the cowl inlet, (from outside of the Jeep - with a flashlight) on both sides, you will see rectangular flaps, about 3-1/2" high by 5-1/2" long. The driver side flap is located approximately above the steering column, the passenger side flap - approximately above the glove box. Have someone pull your fresh air cable and look to see if the flaps open up to let fresh air in. If not, you have a linkage/cable related problem. You can lubricate the flap pivots while the grill is off.
3) If you remove your glove box liner, you will be able to see the cable and cable pivot assembly. It is a poor design and only works properly if all the linkage and cables are in good condition and lubricated properly. If you lubricate the pivot points and cables, I recommend you use a wax based spray lube, that will not attract dust. Cables can be lubricated with graphite as well, (but it can be messy). You'll have to go through a process of lubricating, working the cables, lubricating.................several times.
Hope this is helpful to you.
That is a lot of great info (as usual). I appreciate it. I have a lot to look at now. Thanks.
