Bollocky
Devoted Scrambler
- Charlotte Area
- NC
I abused her friday, that's for sure Drove straight through a field of palmettos and felled pine trees, plowed down the elderberry trees, and didn't even turn away from those eight foot chainlink fences. Although I probibly should have as I got a flat from the second one. (Don't get pissed, I was only tresspassing on a construction site. They're clearing the land for development and the fences and trees I ran down were to go before the 'dozer anyway Quite sadf actually. This area is running out of undevelpoed land)
Anyway, enough bragging. When I changed my tire I found that I could push and pull it about a half inch in line with the axle. When I slow to a stop it does a sort of rhythmic bump and grind, if you know what I mean, like thump-thump-thump-thump slowing as I slow, and a slight bump, especially when doing that Cali stop where I'm barely moving.
'84, my axles are the kind that have four bolts on the back of the backing plate. And I believe that the P.O. upgraded to one piecers.
Anyone know what I screwed up?
