Back again and starting the rebuild
Doc Savage
Greenville
Hello... again. Been away from here for a bit but now coming back. Got a Scrambler back in 05 (https://www.cj-8.com/forum/showthread.php?12141-New-Scrambler&highlight=). It's been a fun vehicle and occassional driver since then.
Didn't do much work on it. Fixed muffler, added tach, seat covers, and light bar (wife's idea, it was her vehicle). well did put new tires on it. It could barely start moving with the 265/75/15s and dropped down to 235/75/15s. Did drive it to Tellico a couple of times for the Dixie Run back in the day. Made the trip great. Been using it mainly for yard work lately.
Well it's getting time for me to get a new jeep. Been running an 05 Unlimited with about 175k miles on it now and wife pays off the van soon, so my turn. Well after a couple of frustrating attmepts to work on the Unlimited due to inaccessability of parts and computer garbage. I thought about getting a CJ. Went online checking prices and things were looking expensive. Finally tole the wife I was wondering about just restoring the Scrambler and that being mine. Suprisingly she said she was thinking the same thing. Looking at putting the money I was thinking about putting into buying a CJ-7 into restoring the Scrambler.
I've made a list of what all I think I need to do and priced it out and I'm real close to my budget (just a bit over, but looking at putting some things off i.e. full soft top). Just need to finish rebuilding the motor for my 98 TJ 4 banger so I can get started on the Scrambler.
Well I have done some (more than planned) work on the Scrambler. I've been poking around at the Scrambler and checking it out every which way to see what will need to be done. Did find a little rust damage that needed to be fixed, Driver's floor looked to have been poorly patched and one rear body mount had rusted out and will need to be repaired. Not too bad beyond that (I thought).
If you check the original thread, you will see the bed and cab had been lined. Over time some of the liner had been coming loose (they had lined the tabs for the tailgate and those fell off). The tailgate was worst. Well yesterday I thought I'd pull that off. Came off real easy and in one piece. Liner was pretty thick. Well I found a small edge of the floor by the tailgate loose, so I scored the loose spot to pull up just the loose, figured I try to just patch it. Well it kept coming and kept coming. Inside 45 minutes I had about 90% of the liner off the floor of the bed. It had a lot of surface rust on the bed (even had water pooled between the bed and liner). Luckly the bed is solid still, just got to the surface.
Today I finished getting the liner off (still have a bit of the top rails to finish. The floors and about the first 3" of the wheel wells and walls came off easy. Rest of it was pulling the paint off the tub as you pealed it off. Someone must not have put much work into the prep work. I was also suspicious of the driver's side floor pan and started pealing the liner there to get a look. Well there wasn't a very good patch job that was lined over there. Have a small hole in the floor now. Liner was holding on to rust and that was about it. Will need to cut out about 8"x18" of the floor and replace it (should have a better feel after finishing pealing the liner, but that is the part where it feels "soft". Probably got the cart before the horse, but one thing lead to another.
I'll be asking questions and posting progress as I go. Plan is to have it pretty well done by April (long story, have plans to donate the Unlimited to some friends who are missionaries).
Plans at this point include: patching tub, painting, new heater core, upgrade heater fan, New tires, New shocks and springs (probably go with a 2.5" lift), Rebuild tranny (shifter has given me some issues in past), Add AC, New tail lights, and new trailer wiring. Planned for a long block swap (hope to not have to though), Planned for a new full soft top, but may hold off on that. Looks like I'll need to regear. Need to check the ratios, but thinking they are the 2.73s. Gears could make the motor feel a bit stronger without doing much to it. Starts and runs great, but seems weak but with the high gears who knows if it is the gears or motor.
Later all.
oh my, just previewed my sig and need to update that, it's OLD!
Ok got to ask a question and not sure where to put it so figured I'd put it here. Reading the thread on Garnet interiors and finally found the trim code list and where the tag is. I immediately went out and took pics of the data tag (and it's 28 degrees out, I must be nuts!). Now I'm more confused than ever. I can't match the numbers on my tags to the decoder that was posted here from CJOffroad.com. On the data tag second line (of numbers not counting the Jeep Corp, Toledo OH first two lines) The center two numbers should be the paint code and the last 3 the trim code. Well my paint code would be 99 and the trim code 6BA. This is an 83 and the VIN on the data tag matches the VIN on the dash and decodes as an 83 CJ-8. Well 99 and 6BA don't show on the decoder from CJOffroad.com???
Any help figuring this out would be appreciated. I'd like to at least know the stock color before I decide on what to go with.
on the photobucket page click into the "direct" link box to the right of the picture, you'll get a little pop up that says "copied"... then back to this page, click the little icon that has a tree in it (fourth from the right when you have the reply-to-thread box open, and the past your link in the tab marked "URL", and un-check the box that says "retrieve file locally" (or something like that)..
hope that helps
