A hacksaw will get you down to what you want... when I built up the last Jeep for a buddy, he was afraid that the tires, shackles, springs and new body would be too high for the garage... we got the 1" kit and cut out 1/2" from it and that lowered it down... still gave a little clearance on the frame, had the poly construction, but lowereed it a bit...
JUST NOTE:
the rear bolts will have to be cut as well or else you will push up the floor in the back... trust me, I know
Hi. Have original style body mount bushings or urethane. Also have steel tube washers, stainless steel- 2 inch washers & the stainless steel bolts & small washers. I have complete kits. I have it all. All I need to know is what vehicle. Merry Christmas. Jim 248-722-9427 jzventuresllc@gmail.com
That is what I used, bought 2" washers and just sized the bolts I needed. I believe there were only 3 different sizes of bolts. One for the front which was 7/16 and the rest were 3/8 with the bushings under each door a little longer. I had CJ springs and used every bushing in the kit. The only thing that was not in the kit was the motor mounts.
