Bolt problem - please help
Darronj
Lehi
UT
So I recently replaced all of my chrome accents with black powder coat accents. The problem I ran into was that the new brackets and such came with black "button head" bolts that use an allen wrench to tighten. Whether it was the powder coat or the rust, etc. several of the bolts wouldn't go in and while trying I threaded the heads and made them useless.
I am wanting to go with hex bolts, but I am not finding anything online that simply offers a black, powder coated hex bolt to replace the piece of crap button bolts.
Has anyone else ever run into this and if so, what did you do?:banghead::banghead::banghead:
I'm sure it is due to the powder-coat finish adding some dimensional size to the fitted parts, therefore making the "male" larger and the "female" smaller. The only black nuts and bolts I've seen are a finish that might be best described as "wrought-iron" finish, where they are a powdery black look and appear like the finish will bleed-off when handled (which it does, to some extent).
