brake help with rear discs
Should the fronts be forcing fluid out from the cap?
Nope, if the lid fits the way it should, there should be no fluid escaping.
And do be clear, I was assuming that you meant that fluid was splashing out when you depress the pedal, not when you release?
I'll try to grab a video of it.
It's all new calipers f/r new rear rotors, old fronts new Flexi fronts and new hard line rear.
It pulls up better now, but a lokar the master shows fluid spilling out from the front reservoir.
It fountains when you depress the pedal.
