Brake line Question
Husker fan
Caro
I recently purchased a 1983 scrambler. The brakes are not so great. They are acting like there is air in the lines. When I bleed the lines it did nothing to improve braking. It is still acting like there is air in the line. My though is that there is a hole in a line somewhere. So I am replacing all the lines and going to upgrade the MC. My question is with the fittings on the hard lines do you need to use Teflon tape on the fittings? Any advice would be appreciated.
If there was a hole there should be leakage. If you replacing the MC is to that first and see if that improves your brakes. You might not need to replace the lines
