Brake upgrade question
RubberDuck
Baltimore
MD
I've seen lots of write ups about YJ brake booster upgrades on CJs but not much about actual CJ factory brake boosters being used to upgrade factory manual brakes. I know it is a direct bolt on to the fire wall, it's there anything involved beyond hooking up the brake lines and vacuum hose? I have factory disc brakes on one axle and drums on the other.
When I did the upgrade I was already running disc f/r, so I ditched the factory valve and went with an aftermarket Summit valve that only impacted the rear. However, when I initially got my booster and was planning the upgrade, my understanding was that valve was the same.
It's really a straight-forward swap. Everything else is the same.
