Camping Trailers
Stouttrout
Registered Jeep Nut
Sour Lake
Tx
i was looking for a small camping trailer for the jeep and thought about converting a CJ7 tub into a pop up for two. Then I ran across this. Looks easy enough to build. Those who have camping trailer, what do you have? I was wandering if anyone has ever seen one of these? I never have. It is light weight and looks perfect. I may make this my winter project.
In Southeast texas you see alot of popup but they are kind of a pain. This thing just looks too cool. His website is :
http://www.outbackteardrop.com/
Needs at least 33's on it though!!!:D
Ran across them last year and thought they were neat. My wife would never go for one since it is too small. But if you are only looking for a hard covered bed and a small open aired kitchen, not a bad idea. With a little extra planning, you could set the axle up on a pivot so when you get to the back roads out west, pump up the hydraulic cylinder and raise the trailer up by 6" to provide off road clearance.
Though it doesn't constiture small, I am looking more at trying to convince the wife to take a 30' fifth wheel cargo trailer and convert the fron 15' into a camper and the rear 15' for the jeep. The rear section would also have a few cabinets for tools and spare parts along with a couple of fold down bunk beds for the kids. Nice advantage to this is the jeep is covered while hauling it, lots of space when you get to camp, and that all important shower and commode. Only drawback is it takes a 3/4 or 1 ton pickup to haul it.
I like your way of thinking...
kohldad said:
[...] I am looking more at trying to convince the wife to take a 30' fifth wheel cargo trailer and convert the fron 15' into a camper and the rear 15' for the jeep. The rear section would also have a few cabinets for tools and spare parts along with a couple of fold down bunk beds for the kids. Nice advantage to this is the jeep is covered while hauling it, lots of space when you get to camp, and that all important shower and commode. Only drawback is it takes a 3/4 or 1 ton pickup to haul it.
I was thinking along those same lines last week... But did not take it much further. Might have to run that past my wife to test the waters whether I should kill any more brains cells mulling it over. Pls let me know if your planning gets past the mental thinking stage and/or you actually do it. I'd be very interested in how you'd do it. (Building the camper portion from scratch or using a commercially built camper minus axle(s)?)
I've got a great running J-20 chassis & running gear that'd make a great fifth-wheel rig... just need a doghouse and cab.
I have to hobbies that I enjoy. One is driving the jeep. The other is Flying RC Airplanes. when I go to a show now I have to stay in a hotel and drive the Suburban. With this I could carry Several Planes and still have a plac to sleep. i was thinking of putting a queen size blow up mattress in it. The I could deflate it and have a covered cargo trailer that would be 7.5' by 5'. Most of my panes aren't too big so I think this will fit perfectly. Plus it will be good for camping which we are starting to do alot of. I did se one of these built on a large trailer. had his 4 whelers in the back.
Dan
Pic of a few of mine.
I've seen those little rvs for sale around here and houston. I would guess they could be sprung over and bigger tires.
As for the others. Yall are making this too complicated. Start with a horse trailer with living quarters. If you've got a skinny jeep and the trailer has a swinging door, all you gotta do is remove the stalls and drive jeep in.
There was a family at the National event from Phoenix that hauled the '8 in one of those "toy hauler" 5th wheel campers. Had lift kit, wide tires and all and still fit. Don't remember the brand but was pretty cool deal.
He may frequent the board and chime in. His name was Dennis, I believe. Brought his wife and 4 kids, from Phoenix just for the Scramble!
Nice folks.
Later
Horse trailer with the dressing room was an idea and would work for a lot of folks. Problem is I want a little more space than what I can afford in a horse trailer (would want a 35' for the 15' dressing room).
Do a search on the web at www.rvtraderonline.com and do a search on keyword for campmaster. While these trailers go for about $18K+ it isn't a bad start. A bare 30' cargo trailer can be purchased new for ~$8K and then it would only take about $5K+ for the materials on the conversion if you can do the work yourself and which ammenties you wanted..
Another option is to buy a fifth wheel and then mount a pckup camper to the front where the cab over is above the fifth wheel. Just need a trailer long enough for your trail rig behing it. Can pick up the fifth wheel for about $5K and then a decent pickup camper or short fifth wheel (axles removed, frame set on blocks for sewage connection clearance) for another $5K.
I have camped in this coleman for years now. I use a sheepherders wood stove for heat on real cold hunting nights!
It is super light weight so I can even push it up my driveway on my own.
I like those. I have purchased a set of plans. I will let you know how it goes. Right now I plan on putting a 25 gal water tank, small a/c, I am putting a single burner stove in a drawer in the galley and if i can find a 12 volt cooler them one of those. I would like to use a swamp cooler but with 100% hummidity in the area I don't think it will work. I will build supports in it for a Kayak rack. i am going to insulate it in one inch foam. Right now i am trying to round up everything i want in it then I will build around it. I just like the fact that I can pull over anyway and don't have to put a tent up. everything is ready to sleep or eat.
I think I can simplify the design by building it straight in the back and flat on top. Overall dimision will be 5x10 + the lenght of the tongue.
Dan,
Where did you get plans from and is there a web sight that gives some basic lay outs of what you are talking about? Thanks...
The best source of info that I found is:
http://www.teardrops.net/
the discussion part of the board has help greatly. I have looked at probably hundreds of site and compiled ideas from all. I ordered plans from tinytearsrecreation on ebay. the plans are for the Boxter. It is most like what I have in mind. the dimesion are alittle smaller but it will give me a good start. I plan on drawing my own plans. on the teardrops.net they have a members sites section. It has a ton of them. I have found a neat product called Filon. I plan on using it inside and out. Oak is too $$$$$$. i well use pre made cabinet doors from Lowes for all th cabinets.
This is the Boxter.
By the way if you go to the discussion part of the teardrop site my name is Dan Engerran. Read the post of mine titled "What Tear : Newcomer Question" Some good advice.
Some of those are quite impressive. The Mueller guys is really sweet. That may be a little beyond my skill...lol.
Still I'm wondering how it would hold up to the pounding off road punishment it would take. The wood construction would concern me for sure...
I think if it is built right it will work. Course that all depends on what type of offroad we are talking. I think alot has to do with the quality of the build.
the lighter the better. Flexable material would have to be the thing. Maybe a composite of sorts would work.
My little coleman has been my home away from home for years and I have had it up on top of the mountain going towards Kingston Peak and in the canyon lands of Utah with only a little rebuilding of the trail for the clearance. I could put a lift kit on mine which would put it up high enough that I could take it on a lot of really rough roads. Which I might?
It is interesting though to see what is being made now for off road campers.
Funny how things work.
About 2 weeks ago I watched a program, I think on OLN, that featured the Teardrop. A week or so ago I came across this thread. Today I see 4 Teardrops, on a flatbed, heading south on I-65. Go figure.
If I wanted to pull my sleeping quarters behind a Scrambler I think the Teardrop would be a good fit. It's practicle and compact and they're both classics.
I, however, don't want to drive the 8 over 150 miles one way anymore. I drove our 8 from KY to Daytona 20 years ago. It had a soft top and I was hauling 2 Harley's on a trailer. That trip beat hell outta me ... and I was young then!
Towing don't exactly thrill me either. What I want is the capability to haul the 8 ... on my sleeping quarters. Seeing as how I ain't rich, what I've considered (a lot) is converting a school bus into a camper/car-hauler.
Any thoughts?
I have a friend that just sold the perfect vehicle. It was a 1975 IH school bus. He took off the back half and, using the frame built an extended bed on the back of it. He is an old three wheeler nut. He could then load up his 3 wheelers and sleep inside. it worked great. I think you have a great idea. My idea is to have the Modified teardrop mount on its own carrier. I could un mount it and lift it over to my Lowboy and mount it to that. I ride ATVs / ATCs, yes, I am a 3 wheel nut too. This way when we go on ride I can have a comfy place with A/C to sleep. When I use it with the Jeep, It will not be too far. Maybe to the beach. I have some property done there and may build on it next year. this would also give me a place to stay while do that.
