Carter carburetor - running too rich?
DRdalequail
San Angelo
TX
Been working on my '81 258; pretty sure it has Carter carburetor on it (how does one know for sure?? Post a picture?)
Starts and idles well but tends to stall at about 35 mph and considerable black smoke. I swapped spark plugs and it's better but still think it's running too rich. Spark plug tips with moderate fouling.
How does one adjust the fuel mixture on this carburetor?
Here are several pics of the carb, and I found it was indeed a Carter. And some pics of supporting evidence for my flooding problem. (Well I see now where I can only attach one pic at a time so multiple posts coming.)
Thanks in advance.
DR
See pic of old spark plug and exhaust "trail" on concrete as evidence of too rich a fuel mixture, correct?
My choke plate sometimes closes completely and probably cause of flooding. This pic shows position of choke plate when idling . . . does that look about right?
Also, see this apparatus (part of the automatic choke?) at tip of screwdriver. I removed a bunch of vacuum lines, but don't recall pulling this one. Is it critical? (Needs to be plugged I presume?)
Old spark plug showing fouling. What else can one discern from appearance of spark plug??
pull the top off your carb and pull out the venturi assembly. Drill the tubes out to .032" use a #67 drll bit I believe. You will be much happier with your jeep
