Cleaning inside the frame
CJocho
CHICAGO
Il
Fellas,
I just cleaned out the inside of my Scrambler frame and thought everyone might benefit from the lessons I learned.
1. Get your frame vertical if at all possible. Gravity helpled so much in getting the larger pieces of rusted metal moving to where you can get them out.
2. Use a kit designed for cleaning a dryer vent. I had to modify it a bit to fit the frame and it worked really well.
3. Occasionaly use compressed air to get pieces and particles moving down the frame.
4. Be patient. The entire process took a couple of hours but well worth the time if you are going to spray some kind in-frame rust encapsulator.
Yikes. That's a lot of crap.
That is a great idea but I have this vision of that frame sliding down the wall and making a bunch of racket. I removed the rear cross member and that made a big difference in accessing the frame from the inside all the way to wheel arches. Then I bought the one from "CHIEFWAHO", and welded that to the frame. Well worth the effort.
Good stuff. Thanks for sharing
