Lookuphere1
- Oklahoma City
- Ok
I have an 83 with a t5 transmission. 6 cylinder. Manuel clutch.
The clutch felt good, except for some chatter starting from a stop in first gear. I had the clutch and fly wheel replaced and related parts. The chatter is gone, but now, the clutch doesn't engage until the pedal is pushed about 2/3 of the way down. The shop is telling me they have adjusted the linkage as much as they can. Any ideas here on how to get the clutch to engage sooner and function more comfortably? I'm told that the old flywheel had some hot spots on it, which caused the chatter.
It's really a pretty simple operation, if you can manipulate one of those common shower curtain rods, you understand the principle of how the clutch adjustment works. If you have a vice grip and a 1/2 socket wrench, you can get under the CJ and check it out yourself.
