Clutch Recommendations --98 Wrangler
Dave K.
Milwaukee
WI
The T/O bearing on my 98 Wrangler Sahara decided to give up the ghost so I decided I would replace the clutch disc and pressure plate while I'm at it. It was actually part of a larger grand-maul failure in which the spring do-hickies on the T/O bearing failed and then the slave cylinder coughed and so on. Long story short--it was pretty crispy up under there with all of the road salt so I decided to pull the engine hence the clutch question . . . . okay, it was still a long story.
Anyway . . . . I don't off-road this thing very often and when I do it's pretty mellow. Would Napa components suffice? Recs on what to buy?
Thanks in advance for the help.
Dave.
