CO2 air tanks, what do you think?
dadscj8
SOA Charter Member
Tucson
Okay, i'm considering going to some kind of a CO2 setup like Power Tank, instead of on board air. What do you folks think? Pros/Cons?
THis is what I use. I run a 350 that I switched from v-belt to serpintine and it was gonna be a real PITA to put OBA on since I would have had to find all the brackets for setting up the compressor. Pros to me....relatively small, easy to locate anywhere in jeep (I've got mine mounted on the pass. side lower rollbar area), portable, hose that they come with is long enough to reach anywhere on the jeep from that spot. I have a local Fire ex. shop that refills it while I wait for about $15.00. I trailer my rig mostly now, and rarely air back up between rides on the weekend. IF I do fill tires...it is quick. Can also adjust pressure if needed to re-seat beads.
Cons: Limited air supply. Cost to re-fill.
If you look around you can probably find the air tank and such for less than they sell it from Powertank.
co2 air
I used an old 10 lb coke compressed container,, the ones used for fountain machines. It was much cheaper than anyone one else. You can order the valves from many places... It is the same size and shape, but you would have to weld a neck protector on..
Hank :D
I got mine from the local fire extinguiser service. They sold me a refurbished tank that had been just tested and then bead blasted. It cost me $90.
It is a 20#. Might actually be a little lagre for carring in the jeep all the time.
I got a fixed regulator from that ballon supply company out in California for ~$30.
When I got the tank filled the first time they gave it to me without the plastic valve protector. Since they had just filled it and would have to empty it to put that handle on my type of valve they said just bring it back when it was empty and they woudl take valve off and put handle on for free. I guess they put those on all of the time. Relativily easy and low cost.
But after having mine. I woudl suggest 10# if you are carring it all of the time. The 20# is a little large. If it is for ARB's only then 5# should be good. but if you are trailering then I woudl suggest a 20# or even looking into a full nitrogen bottle. When we are racing we use the large N2 bottles and fill the tires and run the impacts and air jacks and all from them. Seems to be safer and has more consistent flow. Also bottle does not get frosty and cold liek a CO2 when airing up tires.
So really it is one if those "It Depends" kind of answers. Figure out what you want to do with the source and then go from there.
As for price, check out your local clubs and Fire Extinguisher service guys. And there is a guy on Ebay that sells them for less than that other company.
Carl
