Computer problem/question
2K1TJ
Still Scramblin'
Rockmart
GA
Anybody woth any computer trouble-shooting skills? What is a "Run-time error" , and more importantly, how can I fix it?
Need more info on "Run-Time" error: This just means something blew up when trying to do something else. There should be a "details" section or maybe a little background on what you were doing would help . . .
Aaron
The message was something like " runtime error, object detected, would you like to debug?".
I was trying to view the galleries on cj-8.org and when I moved the cursor over a link I got the error message.
I just tried it on another computer and I didn't get an error so I know it's the computer and not the site. I'm gonna compare the browser settings and see if something's different. Any other things I should check?
You might just try a cold boot. Could be something in the operating system from leaking memory.
usually a good restart will clear it up if it was a bad program causing problems.
Carl
Carl
Yeah, tried that. That's about all I know to do to a computer if it's actin' up :D
Most likely it's a corrupted file with the browser you're using. A fresh reinstall of the browser usually gets rid of the problem.
run-time error: object expected . . . sounds like a script error - you probably have some scripting like JavaScript disabled in your browser. No need to reload a browser, just tweak your security settings.
