mysunnshine
- Phoenix
- AZ
Here's how you test the cooling systems here in Phoenix. It's 112 degrees with 14% humidity today. I figured it was time to do a "real" test on the system since it is worst-case conditions out here right now.
If you have a marginal cooling system out here, you're done....With a 9:1 CR small block Chevrolet motor and a T400 behind it, they tend to build some heat.
