Couple of Questions
Scrambler Guy
Jacksonville
Okay, so now I have this great new Scrambler. The only problem that occurred on the trip home is what looks like a leaky rear axle. It's putting spots all over the one rear wheel. My guess is that it's been over packed, any thoughts? Should I have this looked at and repaired or will it work itself out?
Also, the speedometer isn't accurate. With the 33" tires and 4:56 gears, the speedo is pegged at 65 mph or so. Isn't there a gear I can replace in the transfer case to make it read accurately? I'd like to get this fixed sooner rather than later as it's over doing my mileage.
Thanks
Scott
83 CJ8
Hey Scott,
I can't answer question # 1
But #2 is do-able,
Speedometer gear applet link
When I did mine it cost about $13 dollars & I ordered it at the Jeep deeler parts counter, had it in 2 days..
The little gear goes in where the speedo cable goes into the tranny
amc 20 rear axle
When I got my 8 the rear axle was also leaking. Mine turned out to be the result of a worn out differential bearing.
But a friend of mine's cj7 is leaking right now, and everything inside looks fine.
I think the Amc 20 is notorious for leaking out of the seals. Could have been too much heat build up from the low gears and high speeds?
Anyway, it is a cheap fix parts wise, and I think any mechanic shop should be able to do it.
