Custom Winch Bumper
Raven
Glen Rose
tx
I finally got my winch mounted and bumper completed. I just need to paint the bumper, which I will do on my next trip down to the ranch. Amazing what you can do with some scrap tubing and sucker rod. Then all I need to do is build the high seat bracket to attach to the roll bar and I'm finally almost done!
SC
Raven, nice job,
I have a buddy that wants to put similar rocker guards on his scrambler and is worried that it might be a major pain to unbolt the body mounts to install it(area is alittle rusty). He wants it more for looks and very rarely goes off road. I was telling him that we could cut the bottom of the rockers in half so they come up to the body mounts and then just screw in the rockers down the side of the jeep. In other word there would be no bolts on the bottom just down the side of the jeep. Do you think that would work or will he have problems if people use the step to get into the jeep.
Thanks for the help
Thanks, I would think that if it is purely for looks you should be ok. The rock guards do not bolt underneath ( At least the poison spyder guards do not). They are forked so that they can slide between the body bushing and the frame. I would try to find a way to leave the guard intact & use a dremel tool or something to trim the bushing if you are afraid the bolts will snap I you try to remove them. I believe there are roughly 8 bolts on the side that bolt the guard to the tub. My 8 is 145 miles from house or I would look and check for sure.
Thanks for the reply!
If you can take a few pictures that would be great.
Thanks again for the help.
