D300 speedo gear replacement - but on an '81
AdamH
BENEFACTOR
Surf City
NC
Was about to pull the trigger on a new speedo gear to correct for tire and gear changes and then I read an interesting article.
apparently all 1980 D300s and "some" 1981 D300s are called "shortie" and the gear cannot be swapped out.
I know this may sound as a stupid question but how do I tell if my speedo gear is a shortie?
Measure the output shaft housing from main case. If it is 3 1/2 -ish inches long it is short version. If it is 5 1/2 -ish inches long it is long version.
If you have short version, I think it uses same drive and driven gears as the Dana 20 and 18 cases.
If you have an adjustable eccentric where the speedo cable connects like the photo, then you have a long shaft D300.
Thanks for all the help. Ordered the new gear this morning and prepared the D300 by drilling out the broken retainer bolt.
