Define: Front Dig
ben8jamin
SOA Member & PROUD of it!
St. Simons Island
GA
I read about it somewhere, someone saying they did it. I heard about it on Extreme4x4 TV show and I've been trying to figure out what it is. I've googled and searched forums with no help. Will somebody enlighten me?
A front dig is when you use your ebrake or a cutting brake (a cutting brake allows you to stop one tire or the other or both) or disengage your rear axle altogether (with a twin stick transfer case) and spin the front tires (thus the term "dig") and use that method to move the front end of the vehicle where you need it without having the rear end of the vehicle shoving the vehicle forward.
Here's a video example found on youtube:
The dig is at about 1 min in. Also, you can go to Youtube and just search on front dig and find a lot of videos.
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/5qoWvZCy5Ws&rel=1"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/5qoWvZCy5Ws&rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
that's what i figured. I saw that video last night, when trying to figure it out. the thing i can't figure out is why you would need to to that. you would still move yourself forward with the rear disengaged right? if you ebraked the rear and dug in with the front, what would that gain you? just curious...
In the video above, he moves the front end to the drivers side about 2 to 3 feet without moving the vehicle forward at all. The rear wheels stayed in place while the front end moved into a more desired position.
Its is a technique, especially helpful in rockcrawling when inches make a big difference. Simply a technique to put the vehicle exactly where you need it.
It also helps in very tight corners . . . avoiding a 32 point turn.
