dome light
big_o_
Beeville
TX
Want to put a dome light inside the cab that you reach over and switch on, Any suggestions that run on batteries? Thanks
Thinking of doing the same. Except I have a full top and am thinking of the light that straps onto the roll bar. I would go with LEDs if I were you as they use less battery power (from what I am told)
I have full soft top so I strapped light to roll bar and ran wires inside bar. Hooked up to interior lights on switch.
I was thinking of switching my dome lights to LED. Thought differently after checking out a friends rig with LED's. I was surprised at the amount of light put out by these. Keep in mind when we need them it's usually dark. I walked away totally blinded from the intensity while trying to refocus back to dark.
Batteries will die at some point. Wire it off of the 12 volt system. I got a rear view mirror with built in lights and was able to tuck the wire under the windshield gasket. I also ran these rope lights in the bed. All lights come on when I turn on the factory interior light switch.
