Door options with 1/2 hard top?
How did it work out? I want to try the same thing only I have full soft supertop doors. Was thinking I might be able to use TJ uppers with my supertop lowers and make it work.
I wanted to revive this post to see if anyone has actually done this yet? I to have the YJ lowers and would like to put soft uppers to be able to fully inclose when the weather gets bad.
I will also be selling my full steel doors that came with my 8 as i will never use them.
Thanks
SC
OK, I'm missing something here. Help me understand.
If all the OEM full hard doors from 82 to 95 are intercahngable between the CJ-7, CJ-8, and YJ models, then the hardtops for all should have the same upper door curve or lines.
IF Bestop has the Supertop for the 7 and YJ and you can run full hard doors with the soft top, you would figure the soft top has the same upper door lines. You can also run half doors ( with thier uppers) on the same Supertop.
So is there a DIFFERENT Supertop for those running full hard doors vs those running half hard....doesn't make sense.
So the Bestops rear uppper frame is larger??
Uhhh, I think I figured it out. The harddoors seal closes in on the curved section on the Supertop vertical framework.....where the soft door upper overlaps it for the seal.....thus the extra size in the upper rear of each soft upper......????? and why it won't fit the hardtops of any model.
For now, I'm running a set of OEM YJ half doors (squared upper) on the Kayline full soft top. Not a perfect match, but it works rather well.
Here is a picture of my halfcab with Bestop TJ 2-piece soft doors(handles have been changed to YJ style).
attachment.php
The TJ weatherstripping is too thick, and there is a slight gap at the top of the doors. For as often as I have doors on, it works fine. Probably wouldn't work for a daily driver. Definitely better than no doors on a cold or wet day. Also, the doors easily fit behind the seats if you decide to pull them off in the middle of the day.
Later-
tom82cl8 how did you get the weatherstrip to work ,or does it just fit tight?
The weatherstrip is tight. It will work, but depending on your tub, you may have to slam the door every time to close it. I got tired of doing that and ended up cutting the weatherstrip in half on the lower door. It is possible that you could adjust the hinge and striker and maybe get everything to work. I just didn't spend the time.
Later-
