double check my vin decode, please
WillyT
Scramblered
chicagoish
IL
OK, I'm looking at an 82 Laredo. It's got the clock and tach, so I'm assuming it's legitimate.
Here's what I get from the VIN number (from http://www.jeepfan.com/tech/tech_vincj.htm)
1JCCN88E8CT
1 - USA
J - Jeep
C - MPV (multi purpose vehicle?)
C - 258
N - 5 speed
88 - CJ8
E - 4,150 GVW
8 - ?
C - 1982
T - Toledo
The VIN won't tell you whether it was a Laredo or not. You've decoded all there is to decode.
I believe there should also be another "trim tag" attached near the vin on the firewall, that can be decoded for paint, interior color, etc unless it is rotted off already.
The 8 that you have a question mark beside is called a "Check Sum" It is used to verify that all of the previous codes are correct and it is derived by way of a mathematical formula where each of the previous digits is assigned a number value and then added together. It's only important if there is a concern about a fraudulant VIN.
I understand what you said, but it gave me a headache anyways :rotfl:
The "Trim Code" will tell you if it came from the factory with Laredo seats. You can convert any CJ to a Laredo, but if the trim code tag doesn't have the the correct seats then I would be skeptical. The trim code tag also has the VIN on it, so everything can be matched up.
Black w/stripes = 1EJ
Nutmeg w/stripes = 5EJ
Honey w/stripes = 9EJ
The two digit code is paint color.
I'll have to eyeball the tag and see what it says. But I'm pretty sure it's legit.
Once I hear from the guy about the title being copacetic, I'll probably buy it.
Then it'll be :banghead: all over again :D
