Ive been working on it slowly.
Right now I do have the clear fuel filter on the suction side. The pump is a adv. Auto parts stock mechanical pump, And the Mr. Gasket fuel press reg on the pressure side. I'm going to remove the reg. And put the filter on the pressure side. Once I'm satisfied that the fuel system is working properly I will put a metal filter in place. What I have found out is that if I remove the gas cap the pump has constant fuel. But I also have a problem with the secondarys on the holley 650 dp dripping fuel at idle. So I'm going to pull it and readjust the float again to stop the secondary drip that is causing the motor to run really rich at idle. Any ideas why its pulling a vacuum on the tank?
On a good note I took the wife and daughter on a joy ride around our neighborhood last sat which was fun and the wife said that the new corbeau Baja rs were very comfortable but the side pipe exhaust stinks (because its running rich at idle due to the secondary drip.)
Let me know what you guys think!
