Exhaust question
RubberDuck
Baltimore
MD
Got an exhaust mystery.... working on my project jeep, it came with a factory exhaust manifold mated up to a single pipe exhaust that goes through a glass pack and then Ts to dual pipes. Looks like it was professionally done, welds look good. I get some wicked exhaust fumes in the cab though. Checked all the gaskets on the manifold and the grommet and they look good, Tightened the flange grommet for good measure. A friend of mine swears he cured a similar issue by adding a catalytic converter. All of the smog stuff is gone on this vehicle (4.2 engine) so it stands to reason that could have something to do with it, though I'm not running cats on my 401 and I don't even smell a whiff of exhaust. Thoughts?
If I did add a cat, I'm wondering if I could just cut the glasspack out and replace with a cat. The backpressure can't be that much different.
Where does the tailpipe exit?
You could be pulling the fumes in by draft/vacume
So you can put your hand over the tail pipe and shut down the engine? if you can do that you dont have leaks. You can use a cat as a muffler sure, just wont have a very good tone and prob be louder than a good muffler.
Are the exhaust pipes exiting directly out of the rear of the Jeep or are they at 45 degree angles out the rear behind the back tires? This makes huge difference! My '84 CJ7 has a tailpipe that exits directly out the back and the fumes are horrible (I'm going to be changing the exhaust this summer when I drop in the AMC 360 V8 that is currently in one of my '85 CJ8s which will be getting a built 401!). My '85 CJ8 with the 360 has 2.5" dual exhaust (w/ no catalytic converters) that exits at 45 degree angles from behind the rear tires near the stock location and I have no issues at all with fumes. All of my other Jeeps with the exhaust exiting in the stock locations have no issues either; but my '84 CJ7 with the exhaust exiting straight out the back is bad. It is even worse with the soft top on but no windows or just the rear window out and front widows up. I believe the exhaust exits out the back but is circulated back into the Jeep. The side exit exhaust prevents this from happening.
It exits straight out the back, two pipes straight under stock rear bumper. They probably clear the bumper by 1" or so. Could I be getting blowback into the cab from there? In that case a cat would probably help. Come to think of it, my friend's jeep had his pipes going straight out the back and his fumes were horrible til he added cats.
Thats your problem, the vacume from the body is sucking in the exhaust.
Add the cat if you want, but putting turndowns on the tips out the sides should be done regardless.
Yep, sounds like that is your problem! Like Orionn said, you can still add the cats but until you have the exhaust properly exiting angled out the sides the exhaust will still be circulating into your cab. Having the exhaust properly exit out the side should take care of your fume problems.
mine is out the rear but i have a turn down on it blowing it directly into the slip stream under the jeep. I have no smell but i also have no top at all when its warm.
Hmm, I never would have thought of that. On my CJ-8 with the 401, it has a true dual exhaust setup goes straight out the back with no fume issues, but I think it has a bit more clearance beyond the rear of the jeep. This doesn't have much, 3/4 of an inch to an inch at most. I'll cut off the existing tips and weld in some turndowns, see what that does.
As one of the weird people who actually enjoys trying to breathe clean air, I would recommend both the Catalytic converter and the side exit. :twocents:
This might be a dumb question, but doesn't most vehicle exhaust exit straight out the back rather than making a 90" turn and going out the side? Granted, with turndowns and a cat which this doesn't have... My 66 mustang doesn't even clear the rear of the bumper, doesn't have a cat, but does have a turndown, no fumes...
Should I angle both pipes so they exit behind their respective wheels, and is there such a thing as too much angle?
Most vehicles are not as aerodynamically streamlined in the hinder end as the CJ-8. The old station wagons were close....but you weren't suppose to drive those with the rear window down.
and when you did you have the same problem.
As an example....ever been cought in a rainstorm with all the window on a soft top rolled up? Last time I did I got soaked from behind the vacume pulled the tire spry up and into the Jeep (YJ). same thing with the exhaust.
a 45* angle is enough downward angle, then 30* or so out to the side.
Do that, add the cats and breath clear again :thumbsup:
So I cut the straight pipes off the back and welded on some 45 degree elbows pointing out towards the rear tires, no more stink! Didn't even add a cat, though I may still do that down the road after I see how it behaves in various situations. I had two sources of stink going on.... one was exhaust, the other was burning oil from a small valve cover leak. Changed that out at the same time. It's nice to be able to breathe again in that jeep.
I jumped online to post this very same question. Im sitting here mildly nauseous and headachy after riding eggy for about 20 mins. This is the first time I've driven her since she came out of the shop with the following: new Headman Headers 2-in-1, new Flowmaster Super 50, 2.5" diameter from start to finish.
I've posted a pic of the exhaust outlet. I think they pointed it right, but maybe not?
You need a little more bend to get the pipe headed out the side where as now its blowing to the rear corner of the tub and rolling rite up inside.
Only one way to test it, take it back to the shop and tell them to correct. Mine's pointed parallel with the axles, and I have no issues.
What did that cost you?
Headman Header HED99610 $285.99
Flowmaster Super 50 Muffler FLW52557 $135.99
Labor - Header removal & install, 6hrs x $75 = $450
