Factory antenna
Going Postal
Corvallis
Can anyone show me a close up of a factory antenna? Mine is mounted on the passengers side foot well and looks like it used to have a second mount about 8 inches up the antenna. Need to know what it looked like and i it can be replaced.
If you are talking about radio antenna, mine just mounts on the side at one place. Could it be a AM/FM/CB antenna you had originally that could mount different.
I do have the factory AM FM CB... My antenna has only one wire to the raido in the tuffy console though. Maybe someone swaped the antenna out. I just assumed the AM FM CB used a separate antenna on the bumper.
Mine looks simillar but mounts lower...
My 1981 is mounted on the Driver side. I have a different setup as well?? Mine has a flexable spring on the base to help it from snapping off in the trees. I am the second owner of the Jeep, but I didn't have any prior receipts for any up grade antenna work??
TK
Mine's identical to TK's... or rather, a mirror image. I have the big ol' spring base too, but mine's mounted on the passenger side! Ahhhh... Jeep engineers..... :D
Craig your Jeep looks pretty familiar :D and its an '82.
Mine is the spring type on the passenger side as well. I think any side mount antenna would work though.
I've got one with the second mount higher up. Just a plastic standoff. Don't know if you can order one. I would like to swap with a spring loaded one, then remove or notch out the standoff so it can pop out when hit.
