Thanks all for the help. Turns out I have a 6 cylinder model. I did a little more research myself. According to the Service Manual, it looks like the 6 and 8 cylinder tachs have a black ground wire, orange illumination wire, and 2 red signal wires (one with a white stripe). The four cylinder tachometer has a 3 prong plug with red, white, and black wires. It also has the black ground and orange illumination wire. I found an empty 3 prong plug under the dash, so now just need to find a 4 cylinder gauge..... From what I have read, the aftermarket Omix Ada gauge is wired like the 4 cylinder gauge, but can work with 4, 6, and 8 cylinder engines. Apparently it wires to the negative side of the coil, different from the factory 6 and 8 cylinder models. So, it is not a direct plug in on the 6/8 cylinders. It should work on mine, but I am going to hold out and see if I can find an OEM gauge. Thanks for the help!
