Family Truckster
Well to update everyone, I picked up the '03 Yukon XL 2500 from Oklahoma City, OK and drove it back to Columbia, MO (8 hours each way). Everything went without a hitch and the truck drove perfectly. I just need to do a little routine maintaince on it to make sure everything is where it needs to be for having almost 100k on it. I've been driving it for about a week now and the only thing I've noticed is that occasionally it has a rough idle when cold. The check engine light came on once. I went and had the codes read and it showed a bad Mass Airflow Sensor and a lean condition on two cylinders and a possible O2 sensor problem. Since it only does this on occassion I'm hoping that just some easy maintaince will help. Today I bought some MAS cleaner and fuel treatment/cleaner at the parts store. I pulled the MAS and sprayed it multiple times and replaced the air filter and dumped the fuel system cleaner in the tank. I hope that helps clear up some of the issues. I plan on replacing the plugs and plug wires soon too. If that doesn't clear it up I will start with the O2 sensors and go from there. The only other issue is gas milage. I knew going into this that it wasn't going to get great milage but damn! I averaged 13.9 on the highway with the cruise control set and not pulling a damn thing! Ouch! I was hoping it would get in the 15 range at least!
Congrats. Maybe with the maintenance, the mpgs will get better.
