- Columbia
- MO
It is a 5.5 - 9 psi pump.How big is that pump.. looks very small
Sent from my SM-N910P
Then I believe it is no longer a TBI.
Ok, thanks. I'm going to get a new one just for peace of mind. This one looks to be a generic one. Any one brand better then another?Exactly; it's no longer a TBI. That fuel pump will be fine for your 350. I'm running the same set-up (also with a 4-bbl Edelbrock) for my carb'd 350 in my CJ-7.
Thank you. It has been a much longer process then I ever planned it to be!Fantastic build thread!I started reading and didn't stop until I'd read all 22 pages of it. I can't wait to see the finished project.
I'm running an Edelbrock 1406 on a Performer intake.Whatever you decide on for a fuel pump I would run a return style pressure regulator if you aren't already. For me Edelbrocks always seemed happiest at 4.5 psi. I have ditched many tbis for carbs (usually edelbrock) in my firebirds and got more power and better mpg every single time! Edelbrocks are great, super reliable.
Crush Sleeve Eliminator: https://www.summitracing.com/parts/yga-55040
From what I've read it is the same.Summit lists kit for ford rear ends. Will this work with amc 20 rear end?
