For guys using Rotisserie A warning on under body braces.
jammer1
Maple Hts.
Oh
I did the body work on the sides of the tub. I removed the braces (under the front feet of the roll bar) to epoxy. I then put the tub on a rotisserie to do the bottom. I did the epoxy primer and bedliner. Put the tub back on the saw horses and finished the body including painting, thought nothing about it. Did this in winter (heated building) and left it sit till the next winter. When I went back to continue I found a crack (like the skim coat of body filler lost it's bond). I took it down till I thought I got it and re-did the body work and paint. It sat till this winter. I looked at it and the crack was back.P1090168.jpg This pic was taken in november.
It took a while of thinking back on what I did to realize that without the braces the body flexed (not enough to crack the filler and to be seen). But it must have flexed enough for the crack to be there (under the paint). As it sat the summer it must have cracked the paint. When I took it down to the point that I couldn't see the crack it must have still been there. I also found the b pillar didn't separate from the skin but part of the lip lifted. I slid a putty knife in and it's still has a bond on the inside lip.P1090399.jpgP1090401.jpg I used 3m panel bonding to help make sure it's secure.P1090403.jpg
I sanded the body down to make sure the metal isn't cracked. Found the crack (where filler lost bond) was right next to the spot weld (metal lip of b pillar). I took it down to metal, no crack in metal :rolleyes:. To be sure I cut a piece of 18 gauge sheet metal and made a patch (using panel adhesive) to reinforce the metal.P1090606.jpgP1090608.jpgP1090609.jpgP1090611.jpgP1090615.jpgP1090617.jpgP1090618.jpg
This is just a warning. The tub is not as solid as a cj7 tub. Don't remove these braces on the rotisserie without doing a support to stop it bending. I found out the hard way.:huh:
I've always wondered why some people braced their tub and some didn't. When working on my cowl support this past weekend I got a little antsy and braced the door opening. Your experience has ensured that I'll brace the tub before I put it on the rotisserie this coming weekend. Thanks for the heads up.
I had the tub acid dipped. Before I put it on the rotisserie I removed the braces off the bottom so I could epoxy the braces and the floor under them. When I was done I had to use 1" ratchet straps to align the bolt holes to reinstall. If the braces are off you will have problems. I've seen people do like you said (spot weld 1" angle iron across top of door on tub). I probably should have done that also.
