Fr & rear gear replacement question?
GreatCJ8
Charter Member, 1st SOA Secretary
Lynchburg
yes
if you don't use 4wd on a hard surface you can change them separate...if you are going to use 4wd you need to change them both...
scott
The differance between the 3:73 and the 4:10 is too much-you'll be asking for breakage if you do one at a time and ever put it in fourwheel drive unless your driving on a solid sheet of ice-JC:p
