First time post... I'm having an issue where my front driveshaft out of my dana 300 is occasionally striking the TH350 oil pan. Never had this issue with this same setup in a previous CJ, however, I didn't install these particular motor mounts. My front pumpkin is already as far to the passenger side that it will go without modifying the front axles. Other alternatives include repositioning the motor and trans more towards the driver side or clocking my t-case, which I've never done. Also, my front driveshaft is weighted to balance it. If those weights were in a different spot, they wouldn't hit the pan and only a spinning driveshaft would strike it, which probably wouldn't puncture a hole in the pan. Installing a better balanced driveshaft without the weights would likely help but not solve the clearance issue altogether. Questions: Are there any mods or adapters for a dana 300 that would move the front driveshaft further towards the passenger side? Or, would another T-case, like an Atlas, give me more clearance? BTW, I'm running a SBC.
