Fuel filler and vent hoses
Kansas
Lawrence
KS
Just fixing a leak in my Scrambler tank and wondered if anyone has a better idea than Armour All for restoring the fuel filler and vent hoses. Of course, like the HDPE tank, replacements aren't available. The hoses aren't leaking, they're just cracking and getting more rotten as time passes. Thanks - Bill
Armour all and related products tend to actually dry out the surface they are applied to. I would suggest pure silicone spray, it tends to help preserve surfaces. There may be some after market filler hoses pavailable for the oem 20 g tank.
I believe new hoses ARE available. I just bought new hoses from Morris 4x4 (both filler and vent for an OEM 20gal tank appear to be a perfect match for my '84).
Agreed. I bought mine last year around this time. Can't remember from where, but it might be in my "de-rustification" build thread.
I'm glad to hear that the aftermarket hoses for the 20 gallon tank will fit the Scrambler configuration. Since the CJ7 20 gallon OEM tank doesn't fit a Scrambler I assumed the filler and vent hoses wouldn't either. I'll check it out. Also thanks for the tip on silicone spray. Makes sense to me.
I am pretty sure the oem 20 gallon CJ7 tank fits in an 8(using the 20 gallon skid plate, hose are different though). I know it works from an 8 to a 7
From all I've read the CJ7 tank will not fit in a CJ8. Apparently the bed length on the CJ8 changed the height of the tank. As to the reverse, you may be right. Thanks again to everyone for the sources for filler and vent lines for the Scrambler.
Like everything you hear on the internet, got to take it for what you paid for it.
I have a 20 gallon in my sons scrambler and one going back in mine.
Kind of like the Painless harness for the CJ-7 does not fit a scrambler. But it does. There is different routing in the rear and they use the same length rear harness.
Carl
