Robert Slone
- Spring Hope
- NC
The Scrambler died on the road friday afternoon. I was in 5th running about 72 when it sputtered and began to loose speed. I tried to excellerate but it sputtered so I went to 4th and was able to maintain 65 as long as i was very easy on the pedal. Traffic ahead of me made me hit the brakes and that was it. I figured it was the fuel pump. I've replaced it at least 2 other times in (10 years). I got it towed home and got a new fuel pump. When I pulled the hose loose from the end of the pump gas came running out from the tank end. So gas was running out of the tank and thru the filter and out the end of the hose I had disconnected between the filter and the pump. I caught about 1/2 gallon before I got the hose connected again. As I recall from the other times only about a 1/2 cup drained out from the filter and lines. What's making the gas draw out of the tank? The ignition was off. Should I have disconnected the wiring from the pump first? ( I just now thought about that
